In January my car stalled and had to be towed to my house. I used my scanner/code reader to diagnose the problem considering I do all the mechanic work on my vehicle myself. I got the P0335-Crankshaft Position Sensor A Circuit. I bought a new OEM sensor from the dealer and installed it. While installing the new one, my father over tightened the bolt and broke the harness/plug that locks the harness onto the sensor. I used electrical tape to secure the harness while I waited for the new Pigtails to come in the mail. Fast forward 3 months, its late April. Everything mechanically has been fine with the car. I never did install the new pigtails yet though I have them in my car just waiting. Last Saturday my son and I were just about home after going for breakfast when I heard a "clunk". Immediately my car stalled and the traction control light and the check engine light illuminated. Having this problem a few months back I knew exactly what it was. I pushed my car home, reached where the sensor was and found the sensor still taped to the harness but the bolt holding the sensor into the block was gone. I assumed the bolt somehow backed itself out, so I purchased a new bolt and reinstalled the sensor. She fired right up once that was done. My son and I jumped in and got about 3 blocks, as I pushed the accelerator more than I have the previous 2 blocks, I once again heard the "clunk" and stalled. I reached back down the engine bay and found the sensor still tapped to the harness except the eye on the sensor was broken off, and the sensor was cracked in half.
My question is, what could be causing the sensor to be knocked out the block? Was the sensor cracked after the first time it "backed the bolt out" and it cracked in half the second time from the previous wear? Is the flex plate bent somehow touching the sensor when spinning? If so, wouldn't it hit it every spin and not just when applying more throttle than at idle?
I need to know where to start looking these sensors are $90.00 a piece and I can't keep replacing them not knowing the culprit.
Apr 12, 2022 at 5:59 AM
