Crankshaft sensor
DJHX777
  • 2003 INFINITI G35
  • 83,000 MILES
Replace crank an cams an my car keeps shutting off an I get the same code as I did before I replace the crankshaft sensor but when I get the code now it says pd as a pending code could the sensor be defective sensor need help ASAP car shuts off as driving or coming to a stop
Wednesday, April 24th, 2013 AT 1:47 PM
  • 52,797 POSTS
First we need the code. A code never identifies a bad part just failed systems
Wednesday, April 24th, 2013 AT 4:16 PM
DJHX777
P0335 an is says pending
Wednesday, April 24th, 2013 AT 4:38 PM
  • 52,797 POSTS
DTC P0335 CKP SENSOR (POS)
Component Description
The crankshaft position sensor (POS) is located on the cylinder block rear housing facing the gear teeth (cogs) of the signal plate at the end of the crankshaft. It detects the fluctuation of the engine revolution.
The sensor consists of a permanent magnet and hall IC. When the engine is running the high and low parts of the teeth cause the gap with the sensor change.
The changing gap causes the magnetic field near the sensor to change.
Due to the changing magnetic field the voltage from the sensor changes.
The ECM receives the voltage signal and detects the fluctuation of the engine revolution.
CONSULT-II Reference Value In Data Monitor Mode
On Board Diagnosis Logic
DTC Confirmation Procedure
NOTE: If "DTC Confirmation Procedure" has been previously conducted, always turn ignition switch "OFF" and wait at least 10 seconds before conducting the next test.
TESTING CONDITION:
Before performing the following procedure, confirm that battery voltage is more than 10.5 V with ignition switch "ON".
WITH CONSULT-II
Turn ignition switch "ON" and select "DATA MONITOR" mode with CONSULT-II.
Crank engine for at least 2 seconds and run it for at least 5 seconds at idle speed.
If 1st trip DTC is detected, go to "Diagnostic Procedure". If 1st trip DTC is not detected, go to next step.
Maintaining engine speed at more than 800 rpm for at least 5 seconds.
WITH GST
Follow the procedure "WITH CONSULT-II" above.
EC-POS-01
Wiring Diagram
Diagnostic Procedure Step 1
Diagnostic Procedure Step 2 - 4
Diagnostic Procedure Step 5 - 8
Component Inspection
CRANKSHAFT POSITION SENSOR (POS)
Loosen the fixing bolt of the sensor.
Disconnect crankshaft position sensor (POS) harness connector.
Remove the sensor.
Visually check the sensor for chipping.
Check resistances shown in the figure.
It more involved than replacing the sensor.
Wednesday, April 24th, 2013 AT 4:44 PM
DJHX777
Ok yea I replace it an it came back 3 weeks later an the car shut off an gave that code I just have a obd2 reader that's how I no about that code an thanks for ur help
Wednesday, April 24th, 2013 AT 5:03 PM
Related Crankshaft Sensor Replace/Remove Content
