2003 Infiniti G35 Locating the IAT sensor
76,000 MILES • 6 CYL • 2WD • AUTOMATIC
NICKY D.
I am trying to locate the IAT sensor. I found a two wire sensor on the right side of the motor, in between the air intake and the motor, at the front of the side of the motor. Could you tell me if that is the right sensor?
Feb 3, 2008 at 4:56 AM
BLACKOP555
  • 10,386 POSTS
the MAF sensor is located inline between the engine's throttle body and the air cleaner box, if you take it off it will be circular with 2 wires in it.
the IAT will be located on the intake manifold, but more likely in your case on the air cleaner box.
Feb 3, 2008 at 5:59 AM
