crankshaft sensor
120,000 MILES • 1.3L • 4 CYL • 2WD • AUTOMATIC
VINCENT WILLIAMSON
The check engine light was on, the car does not start sometimes. I had the check engine light tested and it came back as bad crankshaft sensor. I bought a new one replaced it, but the car still does not start. I replaced the bad one and the car started right up and kept starting for a couple of days, but now it wont start at all. is it necessary that I clear the codes first before the new sensor will start the car?
May 13, 2016 at 6:13 AM
CARADIODOC
  • 34,414 POSTS
The mistake is diagnostic fault codes never say to replace parts or that one is bad. They only indicate the circuit or system that needs further diagnosis. First you must rule out grounded and cut wires, stretched and corroded connector terminals, corroded splices, and mechanical problems related to that circuit before suspecting a part that is referenced in the code. In this case you likely have an intermittent wiring problem that was not acting up after the sensor was replaced.
May 13, 2016 at 8:09 AM
