2003 Chevy Trailblazer CKP Wire Colors Fix
240,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
GDOGG79045
I accidentally ripped the wires off my harness to the crankshaft position sensor and I don't know what wire goes where there is a light green, blue, and yellow wires.
Dec 9, 2021 at 11:02 AM
  • 110,248 POSTS
If you take a look at the pic below, it provided the wire locations in the connector. Make sure the pinout picture indicates the wire colors you have. I believe they do, but they also indicate tracer colors you didn't mention.
Let me know if this helps or if you have other questions. Here is one for the 4.3 as well
See pic below.
Dec 9, 2021 at 11:16 AM
AL514
  • 5,700 POSTS
Hello, this is the wiring diagram for the Crank Sensor circuit. Did the wires get ripped out of the sensor connector at the sensor? Are you planning on replacing the sensor or just try to fix the wiring? If it's replaced, you'll need to have the Crankshaft Position sensor Relearn Procedure done with a scan tool that is capable. If the key has been turned on while the connector was unplugged (ripped out) it may need the relearn procedure done, depends on if the ECM lost the Crankshaft variation. I will try to find the connector diagram so you can try repairing it. Okay, Joe took care of that.
Dec 9, 2021 at 11:25 AM
Suggested Repair
Match the light green, blue, and yellow crankshaft position sensor wires to the connector pinout, including any tracer colors shown in the diagram, and repair the harness. If the sensor is replaced, or the key was on while the connector was unplugged and the ECM lost crankshaft variation data, perform the crankshaft position sensor relearn with a capable scan tool.
Conversation Summary
The owner of a 2003 Chevrolet Trailblazer ripped the crankshaft position sensor harness wires—light green, blue, and yellow—and needed the correct pinout. Experts pointed to connector and circuit diagrams and noted possible tracer colors. They also advised a scan-tool crankshaft position relearn if the sensor is replaced or the ECM lost variation data while the connector was unplugged.
