2003 Chevy Trailblazer Belt Squeak and RPM
XPERIENCE
Chevy Trailblazer EXT 03, 55,000, serpentine belts seems to be squeaking adn the RPM Gauge just stopped working. I am not sure what could be the problem I would appreciate it if anyone can help. I was told to just lube up the serpentine belt when it squeaks. I'm not to confident on the answer that I was given so if some can advise or confirm this claim. I would be very greatful.
Mar 24, 2006 at 6:11 PM
PEPPERMRJ
  • 1,158 POSTS
Not a big fan of belt lube either. Inspect the belt for cracks on the ribbed side and replace as needed. If you take it of be sure to check the tensioner, and all the pilleys for noise and resistance.
As far as the tach it is electric. so start by looking at fues, wires, and connections.
Good hunting and let us know. :)
Mar 25, 2006 at 11:24 AM
XPERIENCE
OK, Thank you peppermrj 8) for getting back to me with some options. I do appreciate it. I will check on that. Thanks again :D.
Mar 25, 2006 at 11:57 AM
Suggested Repair
Do not rely on belt lubricant. Inspect the serpentine belt for cracks on the ribbed side and replace it if needed. With the belt removed, check the tensioner and all pulleys for noise and resistance. For the inoperative RPM gauge, which is electric, inspect the fuses, wires, and connections.
Conversation Summary
The owner of a 2003 Chevrolet Trailblazer EXT reported a squeaking serpentine belt and an RPM gauge that stopped working, and questioned advice to lubricate the belt. The expert advised against belt lube, recommended inspecting the belt for rib cracks and replacing it as needed, and checking the tensioner and pulleys for noise or resistance. For the tachometer, the expert said to start by checking fuses, wires, and connections.
