Cranks, starts sometimes
98,791 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
LYNZ
Cranks, starts sometimes, but doesn't run for very long. It only starts maybe 1 out of 25 tries. I was driving it, 95 Ford Taurus 3.0 & it died wouldn't start back up. B4 it died on me, it had started idielling ruff & you could smell gas @rear of car. New fuel filter, fuel pres regulator, plugs, wires. Checked fuel pressure, w/in range. Tested coil, its good. Checked for spark; great on 3 cylinders white/blue other 3 orange. Distributor cap looks good inside, no cracks etc. Tested ICM, good. Its not showing any codes. Need advice on what or where to check next...Thanks
Jan 18, 2016 at 5:49 AM
  • 31,937 POSTS
Do you have the good spark, when it fails? fuel pressure? need to know what is going on when it fails.
Jan 23, 2016 at 11:56 AM
LYNZ
Yes I do. Fuel pressure 38. It doesn't ever start& run long enough for me even to attempt to move it. When it does start it runs ruff then its like its run out of gas, coughs & dies. With my constant tinkering with it, trying to crank it, it has started faulin out the new plugs.
Jan 27, 2016 at 12:42 PM
LYNZ
Sorry don't know why it sent my reply 4 times..
Jan 27, 2016 at 12:46 PM
  • 31,937 POSTS
You should see the fuel pressure rise or drop as it falters what is it doing then?
Jan 27, 2016 at 3:31 PM
LYNZ
When it died, it held at 38.
Jan 28, 2016 at 2:38 AM
NATANYA LEA WIEDMANN
Mass air flow sensor... Would be my guess. Has it been cleaned, checked? Nevermind I see post is very old ????have a good day lol.
Dec 14, 2016 at 4:49 PM
