Cranks no start, no spark
210,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
PALOSBB40
  • 53 POSTS
My car cranks and doesn't start and i checked that it has no spark. I did replace camshaft sensor crankshaft sensor, distributor cap and rotor with new spark plug wires as well as new spark plugs.. did replace ignition coil too. What could be the problem?
Oct 10, 2020 at 7:29 AM
  • 110,251 POSTS
The first thing to check is if there is power the + on the coil. If there is and the coil is new, it could be the control unit. If there is no power, we need to trace it back to the ignition switch.
I attached a pic of the ignition switch below so you can see what I'm talking about.
Let me know what you find.
Oct 10, 2020 at 9:22 AM
PALOSBB40
  • 53 POSTS
Hi, thanks the ignition coil is new and good. but how do i test the ignition switch? When ignition is on position all the dash lights turn on and where is the control unit?.. Thanks
Oct 10, 2020 at 10:18 AM
  • 110,251 POSTS
Start by going to the ignition coil. There should be two wires connected to it in addition to the high tension wire. With the key on, you can use a test light or multi meter to see if there is power at the + terminal on the coil.
Oct 10, 2020 at 10:30 AM
PALOSBB40
  • 53 POSTS
Okay, thanks. i will try that in the morning and let you know. but with my multi meter do i put the negative probe on the high side of coil and positive probe with positive on coil?
Oct 10, 2020 at 10:39 AM
  • 110,251 POSTS
The negative of the meter can be put on any known ground, the body, engine, even the battery negative terminal if it can be reached. The positive on the meter will touch the + terminal on the coil. Don't crank the engine when you do this. It should have power just with the key on (run position).
Let me know what you find or if you have other questions. Don't be worried about asking. That's why I'm here. LOL
Oct 10, 2020 at 10:44 AM
PALOSBB40
  • 53 POSTS
Okay, thanks.
Oct 10, 2020 at 10:46 AM
  • 110,251 POSTS
Happy to help. Let me know the results.
Oct 10, 2020 at 10:55 AM
PALOSBB40
  • 53 POSTS
Hi, I did test the positive side of ignition coil with negative probe on ground and the key tuned on and i got nothing on the meter.
Oct 10, 2020 at 10:32 PM
  • 110,251 POSTS
Then the problem goes back to the ignition switch. That is the next place we need to check. Are you able to do that?
Oct 11, 2020 at 10:40 AM
PALOSBB40
  • 53 POSTS
Hi, i don't know, i'm not a mechanic and don't know where to start on testing the ignition switch. Do you think it needs to be replaced?
Oct 11, 2020 at 10:48 AM
  • 110,251 POSTS
Without testing, it is really hard to be sure. I wouldn't want to say replace it and then find that isn't the problem. There could be a break in the wiring between the two points and a new switch wouldn't fix that.
Oct 11, 2020 at 11:12 AM
PALOSBB40
  • 53 POSTS
Okay, what is the next step?
Oct 12, 2020 at 6:19 AM
  • 110,251 POSTS
Before we move on to testing wiring, lets see if we can retrieve any diagnostic trouble codes. Here are the directions for getting them on this vehicle:
https://www.2carpros.com/articles/bmw-obd1-1995-and-earlier-code-definitions-and-retrieval-procedure
Let me know if you find anything.
Oct 12, 2020 at 11:33 AM
PALOSBB40
  • 53 POSTS
okay, thanks. i will do that tomorrow morning and i will video record it with my phone.
Oct 12, 2020 at 11:42 AM
  • 110,251 POSTS
That sounds like a plan. I will watch for your reply.
Oct 12, 2020 at 11:55 AM
PALOSBB40
  • 53 POSTS
Hi, i was unable to upload the video i took of the Diagnostic Codes. I did review the video serval times and the code i saw was 1444.
Oct 13, 2020 at 7:20 AM
  • 110,251 POSTS
Ironically, that code indicates no codes are stored.
That means we need to go to the ignition switch and see if there is power out from the switch. This means the switch will need removed to access the wiring. At the switch, you will check the wire with the same color as the one on the + side of the coil. It should get power when the key is in the on position.
To remove the switch is a little involved. I am going to provide the directions for replacement. Although you are not replacing the switch, the directions explain how to remove it and then install it. The attached pics correlate with the directions.
_______________________________
1991 BMW 735i (E32) L6-3430cc 3.4L SOHC (M30)
Ignition Switch Replacement
Vehicle Starting and Charging Sensors and Switches - Starting and Charging Ignition Switch Service and Repair Procedures Ignition Switch Replacement
IGNITION SWITCH REPLACEMENT
REPLACING IGNITION SWITCH:
- Disconnect ground lead (battery).
- Remove dashboard trim panel at bottom left.
Cars Without SRS:
- Remove steering wheel.
pic 1
- Unscrew screws and take off lower and upper sections of the steering column casing.
Cars With SRS:
pic 2
- Unscrew screws and take off lower section of the steering column casing.
pic 3
- Pull off plug (4).
- Cut off wire strap (5).
- Loosen holder (6).
- Lift out switch together with the wire harness.
pic 4
- Press in retaining hooks on both sides and pull out the switch.
Installation:
- Check position of the ignition switch to the steering wheel lock.
_________________________________
Let me know if this is something you are comfortable with.
Oct 13, 2020 at 11:43 AM
PALOSBB40
  • 53 POSTS
Hi, thanks for the detailed information and i will try to follow instructions. What does SRS mean? i think my steering wheel has an airbag, so does this mean i wont have to take off the steering wheel?
Oct 13, 2020 at 11:57 AM
  • 110,251 POSTS
SRS stands for supplemental restraint system (AKA Airbag).
Before you start working on it, disconnect the battery and wait for at least 30 minutes. And yes, the directions show it being done without removal.
Take your time. Let me know if I can help.
Oct 13, 2020 at 12:10 PM
PALOSBB40
  • 53 POSTS
okay, thanks. i will take my time and let you know. i have another question my steering wheel doesn't tilt down anymore. I don't know if it was damaged when i got a wheel alignment or when my car was towed when it broke down on an access road, because this happened in the same week.. I think my car got towed by a flatbed. Do you think this could have caused damage?
Oct 13, 2020 at 12:22 PM
  • 110,251 POSTS
It's unlikely. What to do is start a new thread related to how to check and repair the tilt. Also, it's interesting because the wiring runs through the column. I wonder if something has broken the wire.
Oct 13, 2020 at 12:30 PM
PALOSBB40
  • 53 POSTS
Okay, thanks i will do that too. The reason i broke down was a fuel pump issue and once i got that resolved, i noticed still no start, because of no spark.
Oct 13, 2020 at 12:36 PM
  • 110,251 POSTS
You are very welcome. Let me know how things turn out for you.
Oct 14, 2020 at 11:38 AM
PALOSBB40
  • 53 POSTS
Hi, i tried to remove the ignition switch but it wont budge with the flat screw driver. I only saw a clip on one side only and i don't know what to do next. Here is a pic of the ignition switch:
Oct 14, 2020 at 12:01 PM
  • 110,251 POSTS
Do you see a color match for the wire at the coil?
Oct 14, 2020 at 12:07 PM
PALOSBB40
  • 53 POSTS
i don't understand, do you mean the same color wire for the positive on the ignition coil?
Oct 14, 2020 at 12:09 PM
  • 110,251 POSTS
Yes. The wiring schematic I have shows power from the switch direct to the coil.
Oct 14, 2020 at 12:14 PM
PALOSBB40
  • 53 POSTS
Okay, i just checked and both wires to the ignition coil are black for negative and positive.
Oct 14, 2020 at 12:19 PM
  • 110,251 POSTS
Because of the model year, my schematics are very basic and limited. What to do is see if there is a black on on the ignition. Using a test light, see if there is power when the key is turned on and no power when the key is off.
Oct 14, 2020 at 12:26 PM
PALOSBB40
  • 53 POSTS
okay, thanks. i don't have a test light and i will try to figure something out tomorrow. Thanks again.
Oct 14, 2020 at 12:29 PM
  • 110,251 POSTS
Not a problem. Let me know what you find or if you have other questions.
Oct 15, 2020 at 11:09 AM
PALOSBB40
  • 53 POSTS
Hi, i didn't have access to the ignition switch properly, because i couldn't remove the top cover to the steering column, because my steering wheel will no longer tilt down because of damage caused by the tow the truck. i will get back to you when i get this resolved.
Oct 15, 2020 at 11:17 AM
PALOSBB40
  • 53 POSTS
Hi, i'm ready to start working on cranking and no spark. What's the next step for me to look for breaks on no power to ignition coil?
Oct 23, 2020 at 9:13 AM
  • 110,251 POSTS
Have you checked the wire between the two (switch and coil) for continuity? Is there power at the switch?
Oct 23, 2020 at 2:40 PM
PALOSBB40
  • 53 POSTS
Hi, there continuity on the ignition switch, but there no continuity on the wire between my new coil and ignition switch.
Oct 24, 2020 at 1:59 AM
  • 110,251 POSTS
Then there is a break in the wire. If you run power to the coil, will it run? If it does, the wire must have a break in it.
Oct 24, 2020 at 4:11 PM
PALOSBB40
  • 53 POSTS
Hi, how do i run the power to the coil to check it?
Oct 24, 2020 at 9:30 PM
  • 110,251 POSTS
You can take 12v direct to the + on the coil (jumper wire from battery +). Just don't leave it on too long. Just use it to see if it starts. Make sure to disconnect it once you're finished.
Oct 25, 2020 at 11:27 AM
PALOSBB40
  • 53 POSTS
Hi, i didn't have a jumper wire, so i made one from speaker wire and alligator clips. I ran the wire from the battery that's under the back seat to the positive side of coil and when i would move the wire around the positive post i would hear little clicking sounds and chatter. i even heard something click where the fuel injectors are located, but this would happen when the ignition was off only. when ignition key was on i heard nothing. Did try to start car but it still just cranked with no start.
Oct 26, 2020 at 5:45 AM
  • 110,251 POSTS
At this point, I recommend having the coil checked. If you ran power to it, the vehicle should have gotten spark and started. I am going to ask the site owner to look through this thread to see if he can add anything.
I attached a pic below and highlighted where the two retaining bolts are located. Most parts stores can check this for you. Just disconnect the battery before removal.
Take care and let me know what you find.
Oct 26, 2020 at 11:27 AM
