Welcome to 2CarPros.
Are you certain you have spark? Does it sound normal when cranking? Since you have no RPM signal, that is usually a good indicator that the crankshaft position sensor is bad. But you shouldn't be getting spark.
Here are a few links that discuss the sensor I mentioned. They also discuss symptoms of a bad one and in general how one is replaced.
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
__________________________
Also, if you smell gas, and you do have spark, then there is a chance a timing belt has broken, jumped time, or even a bad head gasket causing low compression. A timing belt issue will usually cause the engine to sound odd when cranking it. If you can record it cranking and upload it, I should be able to tell if that is a concern.
I strongly recommend removing the plugs and seeing if they are wet with fuel. Let me know. Also, here is a link that explains how to check for spark. In case you did something differently, try this process.
If the plugs are out, check compression at the same time.
Oct 2, 2019 at 1:00 PM
