Cranks but does not start after getting gas
175,000 MILES
VADERGUY77
The car listed above has had a hard time starting if the day gets super-hot usually will start within 15 minutes. But the last few times it's been as soon as I get gas and it take a long time to start this time it's been 4 hours.
Jul 3, 2022 at 4:01 AM
  • 110,251 POSTS
This could be related to the fuel pump, but (and this is a theory) based on your description, it sounds like it may be a crankshaft position sensor. When they begin to fail, it is common for heat to adversely affect them. Once they sit for a bit and cool down, they work again.
Do me a favor and take a look through this link and let me know if it seems to mirror what you have experienced:
There is a simple way to test this issue. See if the engine starts for a couple of seconds using starting fluid. If it does and then stalls, we know it is fuel related. If there is no change, chances are we lost the ignition spark due to a faulty sensor. So, if this happens, here is a link that explains how to test for ignition spark.
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Try this and let me know what you find. Also, if you have a tachometer in the vehicle, pay attention to it. See if it moves a little when cranking.
Let me know what you find, and I hope you have a great 4th of July.
Jul 3, 2022 at 2:41 PM
