Cranks but will not start
DUDDLES69
  • 1993 SATURN SL2
  • 4 CYL
  • MANUAL
  • 95,000 MILES
I was driving to work last week and my car just died like it ran out of gas. So I figured maybe I had some how got some bad gas or something but that was not it. I changed all the spark plugs because I had them lying on my work bench from the last problem I had with my car. Still nothing, so I changed the crank position sensor with no luck. Replaced all the fuses in both fuse boxes. It gets spark so I am going to try the coolant temperature sensor next. Any idea where to go from there?
Wednesday, December 12th, 2018 AT 7:59 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 47,574 POSTS
When you turn the key on without cranking the engine over can you hear the fuel pump in the tank? This guide will help us get started.
Cheers, Ken
Saturday, December 15th, 2018 AT 10:39 AM
