Engine cranks but will not start
99,000 MILES • V8 • 2WD • AUTOMATIC
TERRY$
Any info will help. thank you
Feb 10, 2022 at 8:54 AM
  • 110,251 POSTS
To narrow things down, have you checked to see if there is spark and fuel to the engine? If not, that is where I need to start.
First, see if the engine will start using starting fluid. If it does and then stalls, we will know it is a fuel-related issue. If there is no change, it is likely ignition related. Here is a link that explains how to check for ignition spark:
Additionally, here is a link that reviews the most common causes of a crank no start condition. Take a look through it to see if it helps.
https://www.2carpros.com/articles/car-not-running-advanced
Feb 10, 2022 at 11:41 AM
Good morning,
You need a spark, fuel pressure, and compression for the engine to run.
I would rent a tester at a parts store and test the actual pressure to be sure the pump is working correctly.
I would also check for spark. A guide is below for you to follow:
Lastly, I would check the compression to be sure the timing is correct for it to run.
Let me know the results so we can proceed.
Feb 10, 2022 at 7:10 PM
