Cranks but start but can be pull started
SAMMELTON
  • 1991 CHEVROLET S-10
  • 2.5L
  • 4 CYL
  • MANUAL
  • 200,000 MILES
The engine cranks off of the key but won't the coil does not fire does get fuel but it can be pull started an fires up an runs perfect I have changed the distributor + cap an rotor, the coil, the ecm, the ignition switch, I have re grounded wires from body to engine from engine to the battery an from the battery to the body now an then after pull starting it it will start off the key may start all day then it just stops again until I pull start it again please any info or suggestions would be greatly appreciated thank you
Saturday, December 27th, 2014 AT 10:45 PM
HMAC300
  • 48,601 POSTS
Check the dist as a lot of these earlier ones had reluctor problems and wouldn't start. So the dist had to be replaced. However this is just a guess because of the no start it would need to be physically looked at in order to properly diagnose it. Check the fusible links that run off of battery and alternator they should have 12 volts at both ends they my be just hanging on by a thread
Sunday, December 28th, 2014 AT 7:24 AM
