Lights, radio and other electrical
Check for a short in your ignition switch and fuse block.
Make sure you have the correct amp fuses in place.
Engine cuts off
If you have an Ohm meter, volt meter, amp meter, or multi meter, check for current at the fuel relay, injecter wiring, TPS, IAC and MAP sensor.
SPONSORED LINKS
Thursday, November 27th, 2008 AT 12:52 AM
