Cranks but no start
100,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
PAUL BAKER III
It cranks but does not start. I put a scanner on it and replace the camshaft sensors, the exhaust and the intake sensors and then I replaced the crankshaft actuator position sensor. Go to start it and it cranks and cranks and cranks acts like it wants to start but won't start.
Apr 21, 2021 at 4:33 AM
Two things we need to start with. First fuel pressure and then compression.
https://youtu.be/dCjmRL3p4Cs
Sounds like it is a fuel pressure issue but the fact that it sounds like it is trying to start sounds like it could be a timing issue and we will most likely show up on a compression check. More then likely it will be lower than normal but not 0 PSI.
Let's start with this and go from there.
Apr 22, 2021 at 11:06 AM
