Cranking but not starting
156,000 MILES • 1.0L • 2WD • AUTOMATIC
OUNDOMAURICE
My car cranks but cannot pick to start engine. At times it starts and at times it does start however long you might crank.
Sep 8, 2018 at 1:03 AM
  • 110,244 POSTS
This could be a few different issues. I suspect there may be an issue with fuel pressure. I need you to check for fuel pump pressure. Take a look through this link. It explains how the process is done. I think you may find low pressure.
Https://www.2carpros.com/articles/starter-not-working-repair
Let me know what you find.
Sep 8, 2018 at 12:30 PM
OUNDOMAURICE
I bought a new fuel pump, new spark plugs but no difference.
Sep 8, 2018 at 2:40 PM
  • 110,244 POSTS
Hi again:
Okay, if the pump is new and you confirmed the pressure is within the manufacture's specs, then we need to look at spark. I realize there are new plugs, but other things can cause spark issues. My first concern is the crankshaft position sensor. Take a look through this link:
When the engine will not start, check to see if there is spark to the plugs. Here is a link that shows how it is done:
Let me know if this helps or if you have already checked.
Sep 9, 2018 at 10:02 AM
