Crank will not start
LYNNE TULLUS
Van quit running and I had thought to be out of gas so put gas in and then the starter just made a spinning noise so I replaced the starter. Now it cranks but won't start. When trying to start it it runs the battery down quickly.
Jul 30, 2020 at 11:56 AM
  • 110,248 POSTS
Is it possible for you to record it cranking so and upload it for me to hear? Also, it still could be a fuel related issue. Anytime a vehicle just shuts down like you described, it is usually related to fuel or an ignition issue. Try this. See if it starts for a couple seconds using starting fluid. If it starts and then stalls, it is a fuel related issue. If it still doesn't even try to start, then it is likely ignition related.
Here is a link that you may find of interest as well. It relates to a crank no start condition.
Let me know what you find. Also, if you could upload the audio of it cranking, I would like to hear it. The idea that it is draining the battery quickly is a concern to me.
Jul 30, 2020 at 12:07 PM
