Codes P198, P335 and P523?
BHAMDOC1973
  • 1,657 POSTS
I meant oil pressure.
Thursday, November 10th, 2022 AT 5:06 AM
  • 109,885 POSTS
No problem whatsoever. As far as the blue wire is concerned, it will be a dark blue wire with a dark green tracer. Let me know if that is what you needed.
Thursday, November 10th, 2022 AT 6:51 PM
BHAMDOC1973
  • 1,657 POSTS
Yes, I think I found it, it's the thinnest blue, the other two wires are confusing. Hoping they both give same signal; one goes to the main harness of the CPS the other to the oil pressure sensor.
Thursday, November 10th, 2022 AT 6:53 PM
  • 109,885 POSTS
That sounds correct as far as where it is going. Let me know what you find or if you have questions.
Thursday, November 10th, 2022 AT 7:39 PM
