I started having an issue with sluggish driveability and occasional hard starting. Figured it was a great time for little upkeep on my van.
Replaced:
Fuel pump
Fuel spider
Upper intake manifold
Distributor
Ignition coil
Spark plugs and wires
Today I went to button it all up and no starting. Cranking but not starting.Went down the line and thought maybe it's crankshaft sensor, which could have caused original starting issues.
Noticed quite a bit of oil caked on bottom of my engine but no oil spots on ground.
Removed crank sensor and 1-2 cups of oil poured out.
Crankshaft shaft seals must be toast. Besides crank seals, what else do I need to consider?
4.3L Vortec 2500 v6
Replaced:
Fuel pump
Fuel spider
Distributor
Ignition coil
4.3L Vortec 2500 v6
Nov 5, 2019 at 2:20 AM
