We drove it shut it off then no start first it wasnt gettin fuel so changed fuel pump then it still will start and shut off with starting fluid but is gettin fuel so then changed cap, rotor, ignition coil, crank position sensor and had the ignition module tested and was good still wont start but it will with starting fluid. What else should I check?
SPONSORED LINKS
Saturday, October 24th, 2009 AT 12:14 PM
