Crank no start
200,000 MILES • 5.2L • V8 • 4WD • AUTOMATIC
BIGSMITTY1030
half ton truck. I just replaced transmission and the truck will not start. Drove truck into garage to change transmission and now crank no start. Checked several grounds all appear good. Fuel pump only activates when I jumper it at the relay. Coil is not receiving twelve volts on bottom side at haywire. Which means no spark. All this points to PCM not triggering ASD relay. suggestions? I have changed relays and no change.
Jun 17, 2017 at 4:46 AM
CARADIODOC
  • 34,415 POSTS
Chances are the crankshaft position sensor got damaged if it wasn't removed before the transmission was removed. Pull that out and check it first.
Jun 19, 2017 at 1:51 PM
BIGSMITTY1030
I forgot to put that in the original post my bad....... changed that.... still no start...... put a pcm from a 98 in it.... fired right up.
Jun 20, 2017 at 1:09 AM
CARADIODOC
  • 34,415 POSTS
I'm skeptical, but there's no arguing with success. Chrysler has very little trouble with their Engine Computers, and it seems strange one would work fine driving the truck into the shop, then suddenly not work after the service was completed. I'd be tempted to reinstall the old computer to see what happens.
Be aware too that when power is lost to the computer, either through disconnecting it or the battery, it loses its memory. Most information, like fuel trim data, will be rebuilt as you start driving again, but "minimum throttle" has to be relearned before the computer will know when it has to be in control of idle speed. Until that is done, the engine may not start unless the accelerator pedal is held down 1/4", you won't get the nice idle flare-up to 1500 rpm at start-up, and it will tend to stall at stop signs. If you run into that, to meet the conditions for the relearn to take place, drive at highway speed with the engine warmed up, then coast for at least seven seconds without touching the pedals.
Jun 20, 2017 at 1:26 PM
