Okay, so I guess I will try to use old one until I can get flashed. But any suggestions on where to start? Because not only did I lose fuel from the module I am pretty sure I have lost spark and not sure what would cause it to loose both. When I drove it the night before those all happened.
SPONSORED LINKS
Friday, March 22nd, 2019 AT 12:38 PM
MECHANIC
You need a working PCM before you can start with the checks.
The old one will not work now since you put another in the car.
Friday, March 22nd, 2019 AT 12:42 PM
JWR2009
MEMBER
Ok so now im trying to see if the pcm has power and see what all I canfigure out. I am looking for what wires get power to pcm I looked on diagrams and I cannot see clearly enough to see what colors get the power I know it is only 5v but not sure which ones
Sunday, March 24th, 2019 AT 10:27 AM
JWR2009
MEMBER
Okay, so I have played around with the car today. I am am leaning towards the PCM was bad from the start before swapping. So far I can get it to run with starting fluid. It has no fuel in rail. I jumped it out and has 12 volts on the injectors. But not sure on how to make sure they are firing. I am looking for a place to buy a PCM or reprogram one that I pulled not the original. I am at a loss of what my next step will be after I get a new one or reprogrammed. I will keep you posted after.
Sunday, March 24th, 2019 AT 5:18 PM
MECHANIC
You can get one from rockauto. Com.
As far as programming, you need a shop that has the equipment to perform this operation. The last resort is the dealer who will charge you a lot of money.
SPONSORED LINKS
Monday, March 25th, 2019 AT 3:15 AM
JWR2009
MEMBER
I am going the route of an online store and it is programmed to VIN and shipped to me. So it will be here by the weekend for $145.00. So I will have to see.
Monday, March 25th, 2019 AT 5:02 AM
MECHANIC
Sounds like a plan.
Monday, March 25th, 2019 AT 9:38 AM
JWR2009
MEMBER
Okay, so been a while played around a little but only thing I have figured out is no pulse for injectors I have hot. Also the digital dash messaging center I cannot get to work. Any help is appreciated.
