2000 Lincoln Continental engine does not trun over, all lig
2000 LINCOLN CONTINENTAL
56,000 MILES • V8 • FWD • AUTOMATIC
LLESSOR
engine does not trun over, all lights, elec. work.
lights do not dim when key is turned.
at first engine did turn over but not start, after checking fuses [those checked were good] engine would not turn over at all. Where and what to check next??
Dec 31, 2009 at 1:34 PM
Cranks and w/n start
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
No crank at all/nothing/nada:
Could be the starter, starter relay, park and neutral switch and ignition switch assuming the battery and connections are good.
Dec 31, 2009 at 1:44 PM
