Crank but no start?
144,000 MILES • 1.7L • MANUAL
SHADOW95
It all started with the heater. When I was driving the heater worked amazingly but once in idle it would blow cool air. So, I added engine coolant after it started to smoke and that worked but after that the car started to shake as if it wanted to but did not, so I replaced the radiator hoses, radiator, spark plugs, ignition coil, radiator cap. Then it started to have a delay start and I was told to replace the fuel pump and I did but now the car cranks but won’t start. I can hear the fuel pump start up. I need help please.
Jan 25, 2023 at 8:43 AM
  • 55,740 POSTS
It sounds like the engine overheated. How does the engine sound when cranking over? Can you upload a short video of the engine cranking so I can see if the engine is any good? So, will the engine run on starting fluid? If so, it will be a fuel pressure if not we need to check for spark, this video will help:
https://youtu.be/baq_aEWNQ0Y
Also please go over this guide for ideas as well:
https://www.2carpros.com/articles/car-not-running-advanced
Please go over this guide and report back.
Jan 26, 2023 at 4:58 AM
