2002 Honda Civic car wont start on really cold mornings
RIFF44
  • 2002 HONDA CIVIC
  • 4 CYL
  • FWD
  • 110,000 MILES
On really cold mornings in chicago when temps are around 0 or below the car will just crank but not fire. Usually after letting it sit until around 930 am the car will finally start
Wednesday, January 30th, 2008 AT 2:06 PM
Checked the coolant temperature sensor and fuel pressure.
Give me the type of Ignition and Fuel system you have?
Wednesday, January 30th, 2008 AT 2:25 PM
TOPGUN1226
  • 29 POSTS
How long is it cranking for? Do you notice a difference depending on the amount of fuel in the tank?
Reason I ask is because I have a `00 Civic LX (different model generation) and it tends to have a slower start (4-5 seconds of pressure on the starter on first start) when I only have 1/2 tank or less; when it's above that, it usually comes on it the first 2 seconds of pressure on the starter.
I also notice more "pep" and "pickup" when the car is over 1/2 a tank also.
Another thing I used to do when I owned a Jeep was to press on the accelerator twice quickly before starting. That seems to help on colder mornings and helps speed up the start.
Friday, February 1st, 2008 AT 3:30 PM
