Crank but no start?
103,000 MILES • 1.9L • 4 CYL • 2WD • AUTOMATIC
THEDIZZ112278
I was driving to work one day last week, and the car shut off after getting off the interstate and hasn't fired up since! I replaced fuel pump, PCV valve alternator, battery, etcs, and am about to replace the crankshaft position sensor now and the starter when it arrives. I don't have any transportation and don't have a multimeter or test light!
Apr 1, 2023 at 11:38 PM
  • 110,248 POSTS
First, if the starter is engaging and turning the engine normally, send the one ordered back. Yours is good.
Next, it sounds like the crankshaft position may have failed. Here is what to do: See if the engine starts when you use starting fluid. If it does and then stalls, we know it's a fuel-related issue. If there is no change, chances are there is no spark to the plugs (likely crankshaft position sensor).
Try this and let me know what you find or if you have questions.
Apr 2, 2023 at 1:07 PM
THEDIZZ112278
Okay, I replaced the crankshaft position sensor no change and it doesn't fire up with starting fluid!
Apr 3, 2023 at 7:50 PM
THEDIZZ112278
Could it be the timing chain has broken or something? But there weren't any weird noises when the car shut off!
Apr 3, 2023 at 7:51 PM
THEDIZZ112278
I went ahead and ordered a PCM might as well when I do find the issue, I'll have almost all new bolt on parts! Lol!
Apr 4, 2023 at 12:46 AM
  • 110,248 POSTS
Make sure the PCM you get is plug-and-play. You don't want to go through programming issues.
Also, if I understand correctly, the PCM has been replaced, and there is still no spark at the plugs. Is that correct? If you have a live data scan tool, see if there is an engine RPM signal present when cranking the engine.
Apr 4, 2023 at 12:31 PM
