1995 Saturn SL1 car won't start
RAVENMASTER
  • 1995 SATURN SL1
  • 4 CYL
  • FWD
  • 130,000 MILES
Car will turn over, replaced the battery with new one, replaced the coilpack used one, gets spark to the plugs, and gas to the injectiontors, did compression test on all cylinders, from 135 to160
Sunday, December 27th, 2009 AT 10:13 PM
You are getting spark and fuel that's if your fuel pressure is within specs and injectors are pulsing if all are okay and still won't start, check the valve and ignition timing if its off you can crank all day and she'll never start
Sunday, December 27th, 2009 AT 11:46 PM
RAVENMASTER
Thanks of the first question, where is the valve & ignition, on the car
Monday, December 28th, 2009 AT 3:33 AM
RAVENMASTER
Thanks of the first question, where is the valve & ignition, on the car send photo, thanks
Monday, December 28th, 2009 AT 3:35 AM
