Different guy (dealing mostly with carbureted vehicles).
I went to the engine performance diagrams in "Prodemand" to see if I saw something that might help. There were five diagrams just for engine performance.
As with most all modern vehicles the computer(s) itself is always a possibility.
Other than that, wires, grounds, relays, fuses, and components are about all that is left to go wrong. A "good fuse" may have corrosion on one of its legs, a "new" fuel pump may be bad right out of the box or installed incorrectly.
Beings that it does run on starter juice, you can eliminate a bunch of other possibilities!
Lets go basic!
"Prodemand" is showing two fuel tanks (this may be an option) Are you trying to run off of one with fuel in it? Have you tried switching tanks?
Even a more critical, but simple test! (even though you did post a fuel pressure value) Double checking stuff might help out!
When your key gets turned to "on", the fuel pump should run/ hum for a second or two. Usually it can be heard in the cockpit. To be certain, remove the fuel cap and have your buddy listen near it when you turn the key to "on".
This might give a better idea of the fuel pump situation.
Your turn,
The Medic
Sep 2, 2020 at 5:58 AM
