Coolant leaking
268,500 MILES • 6 CYL • 2WD • AUTOMATIC
JCORT1006
Hi there, so it looks like there's coolant leaking from my car. I took it for a smog check to my repair shop just a week ago and they found out there was a leak and a water outlet was needed to be replaced because it would overheat the car and engine. I replaced that outlet as well as the thermostat and added coolant. A week later and there's no coolant on the radiator and reservoir. I'm afraid there could be a leak somewhere else. Any idea what else could it be? I know the car could be on its final stage because of all the miles I've driven on it. Thank you
Jan 15, 2019 at 10:00 AM
  • 110,248 POSTS
There are many places where coolant can leak. Hoses, the radiator, cylinder head gasket, freeze plug, heater core. the list goes on. Here is what I need you to do. Follow this link. It discusses how to identify where a leak is coming from. Additionally, I am going to provide a link that shows how to pressure test the system. You will need the tool to do it, but most parts stores will lend you one.
https://www.2carpros.com/articles/car-is-leaking-coolant
https://www.2carpros.com/articles/radiator-pressure-test
Once you determine where the leak is located, let me know what you find. I will provide the directions to repair it.
Take care and let me know if you have other questions.
Jan 15, 2019 at 10:48 AM
