Coolant leak?
DASANI
  • FORD TAURUS
My car is leaking anti freeze smokes a little but coolant level in vech doesnt show im over heating, I just repaired an over heating problem but mechanic with out even looking at it says its a total different repair. I dont no anything about cars so im not sure if he just said that to get more money or what the problem is
Friday, August 21st, 2020 AT 1:35 PM (Merged)
BOOTDOG
  • 665 POSTS
Have the system pressure tested. This will expose any external leaks. If the vehicle is blowing out white smoke from the tail pipe then you have a combustion leak. Just throwing that out there cause you said it smokes.
ESE_LERCH489S
  • 2000 FORD TAURUS
  • V6
  • 150,000 MILES
So yesterday I drove to Target. Once I parked I noticed my car was leaking a reddish orange liquid from the front of my car. Coming out of these little circle holes right under the front of the hood. I left inside the store to come out and notice a puddle that formed and spilled onto the sidewalk. I called my dad and he suggested it was the coolant. I left home keeping an eye on my temperature gauge but it was normal. No overheating or nothing. Car seems to run fine but the leak is very concerning.
Friday, August 21st, 2020 AT 1:36 PM (Merged)
STEVE W.
  • 13,584 POSTS
Reddish orange sounds like coolant. It could be from pretty much anything, hose that is failing, radiator that has a crack, overflow return line and others. The only way to find it would be a visual inspection, looking for the wet areas where it is leaking. The thing with coolant leaks is that depending on what it is you could easily have a catastrophic failure once the engine and coolant are hot. Also the leak will usually leak more when the engine warms up and the coolant expands. The first thing I would do is check the actual coolant level, then use a pressure tester to find the leak. That allows you to apply pressure to a cold cooling system and look for the leak without burning yourself or risking engine damage.
https://www.2carpros.com/articles/radiator-pressure-test
The repairs would depend on what you find as a leak.
RAYMOND2008
  • 2000 FORD TAURUS
  • 6 CYL
  • 86,000 MILES
The leak is slow, how to find the leak place
SERVICE WRITER
  • 9,123 POSTS
The best way is with a pressure tester.
Or
You can bring the engine to temperature so the system is pressurized. Then with good lighting and dental nmirrors of needbe, start your search.
Are there any signs of leakage?
VIKADELIC
  • FORD TAURUS
Yes I Have a Ford Taurus 2000 DOHC and I was wondering if you still use 50/50 ratio or does it need to be refilled with straight coolant. Cause my Cap says Atifreeze only. But the book I got Says add 50/50 ratio to my expansion tank after draining. My car is overcooling itself, So I am checking for proper coolant ratio to get my heat back. Heres whats happening. The car heater inside is all the way and the fan is blowing on full too. When it idle it will warm up but not to a point where you have to turn the heat down and when I am driving the air get s cooler then warmer. I figured maybe the thermostat.I dont see ant coolant leaks but can smell it after diving home when I park it back in the garage
TAURUSWHEEL
  • 718 POSTS
Mixture is 50 50, what does overcooling mean? Getting the heat back, does that mean you have lousy interior heating? Or the engine is running cool? Is the fan running all the time without the compressor on? As long as the thermostat is doing it's job, car should be near normal temps, that's it's purpose.
MATHIASO
  • 1,209 POSTS
To TaurusWheel
An engine that runs too cold and fails to reach it normal operating temperature.
A lack of heat in the passenger area is often the first sign that indicates an overcooling problems, but not always.
When the thermostat sticks in its open position. It allow coolan to flow trough the radiator at all the time, causing only cool air in the passenger area.(Overcooling)
TAURUSWHEEL
  • 718 POSTS
Yeah I know, I was trying to get some info as to whether" trying to get the heat back" meant no interior heating, or getting the car running at normal op temps, sometimes I don't read well, or the questions are not framed too well.
MATHIASO
  • 1,209 POSTS
To vikadelic
A 50-50 mixture of antifreeze and wayer that 's presurized to about 14 psi won't boil until it reaches a temperature of about 260 degrees.
50-50 % is correct.
Your cap saying "antifreeze only" mean that do not put oil, brake fluid, power steering fluid. BUT antifreeze only and that is 50-50 or according to your book.( 50% antifreeze - 50% plain water)
For the overcooling problem check if the fan is working all the time ( and let me know)
otherwise, remove your thermostat and check it. :)
PATRICIA BECKWITH
  • 2000 FORD TAURUS
  • 6 CYL
  • 122,762 MILES
My car has a crack in the coolent an its smoking an leaking. How much do I need to pay for a new one?
BMRFIXIT
  • 19,053 POSTS
Have to have a coolant system pressure test to locate the leak, once leak located let me know where is the leak for an estimate to have it fixed
