Convertible, trunk stuck up
150,000 MILES
SHANNON EMMONS PORTER
When putting convertible top down the trunk is stuck up. Is there a manual way to lower the trunk?
May 1, 2021 at 5:14 AM
  • 110,248 POSTS
To the best of my knowledge, there should be a manual way of doing it. However, I am not able to find anything related to it in the manuals. I remember on the older ones, there was a knob in the trunk which would operate it manually, but this doesn't seem to have that option.
Here is what I suggest trying. The vehicle should have the CAN system scanned for diagnostic trouble codes. CAN stands for controller area network. Basically, all the computers/modules are tied together via a few wires. By scanning the can, it should identify if the problem is related to a position sensor failure, module failure, and so on.
Here is a quick video showing how it is done:
https://youtu.be/InIlnsjOVFA
If you can, have this done and let me know what codes are found.
May 4, 2021 at 12:32 PM
