Convertible trunk
86,000 MILES • 2.4L • 6 CYL • 2WD • AUTOMATIC
SCOTT CARPENTER2
So a while back my convertible top got stuck in the up position. A cable had broken apart that goes in the motor that raises the trunk lid up and down. So disconnected the pistons so that I could lower it manually, effectively rendering the convertible useless. I have since fixed the cable and motor. now i just need to open the trunk and reconnect everything else. Is there a way to manually disengage the locks so i can open it? The trunk opens fine in normal trunk operation. I need to get it to open for convertible operation, if that makes sense.
Jul 15, 2017 at 3:45 AM
STEVE W.
  • 15,418 POSTS
Unlock the rear of the trunk lid with the key. Go in and on the side of the hydraulic pump there is a release valve. Release it and then push down on the cylinders until the deck latches release. Then have a helper grab one side of the lid and you on the other, lift and pull toward the rear to put the lid into service position. Put a prop rod in place to hold it open.
Tighten the control valve.
Reverse the process to close it.
Jul 16, 2017 at 7:24 AM
