2012 Audi A5 Convertible Top Code B11A002 Fix
Suggested Repair
Inspect the convertible top closing switches—top left, top front, and top lock—for a broken, loose, or non-contacting switch. If the top still will not fold after the emergency levers are used, try the suggested hard reboot: disconnect the negative battery cable and hold it to the positive terminal for one minute to discharge BCM and PCM memory, then retry the top.
Conversation Summary
The owner of a 2012 Audi A5 reported a flashing convertible top light and code B11A002, and could not fold the top or unlock the rear glass after using the emergency levers. The expert said the code indicates a closing switch that is broken or not contacting, and advised inspecting the top left, top front, and top lock switches. The expert also suggested a battery-cable hard reboot to clear module memory. The owner said they would try it.
