2000 Jaguar XK8 Convertible Top Stalls
2000 JAGUAR
TOM47
The hydraulic fluid has blown out twice causing replacement of pump and hoses. Most recently last week.
The top still does not come up smoothly and stalls several times on the way up. Three dealerships have not been able to slove the problem.
Sep 10, 2007 at 11:02 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like something is getting in the way causing the pump to over pressure the system.Has the car ever been in an accident? Have you tried unhooking the hydraulic ram to see if the top moves freely on its own?
Sep 11, 2007 at 12:45 AM
Suggested Repair
Check for a mechanical obstruction or prior accident damage that is overpressurizing the convertible-top hydraulics. Unhook the hydraulic ram and confirm the top moves freely on its own.
Conversation Summary
The owner of a 2000 Jaguar XK8 says convertible-top hydraulic fluid has blown out twice, leading to pump and hose replacement, but the top still stalls several times while raising. Dealerships have not found the cause. The expert suggests something may be binding and overpressurizing the pump, and recommends checking for accident damage and unhooking the ram to test free movement.
