Low engine power
ZACKMAN
  • 4,202 POSTS
Sounds like ignition problem. When was the last time you did a full, complete tune-up on this vehicle?
Friday, August 23rd, 2019 AT 1:40 PM (Merged)
AUTOTROPOLIS12
  • 18 POSTS
This is the Sounds like ignition problem show the mechanic.
BSULLI1043
  • 2002 BUICK REGAL
  • 6 CYL
  • FWD
  • 115,000 MILES
I recently had a tune up including spark plug wires and an EGR valve replaced. 400.00 later I still have the same problem. The car does not want to accelerate over 35 mph and I am being told different things by different people. Do you have any ideas.
Have the TPS/MAF/MAP sensors checked out to include the fuel pressure. These components are okay-Get the tranny checked-
KAMZ100
  • 5 POSTS
  • 2002 BUICK REGAL
  • 6 CYL
  • FWD
  • 68,000 MILES
. Hi my 2002 buick regal rmp gauge goes up but the speed gauge stays the same, basically the car does not goes fast as I press the gas pedal, instead the rpm goes up and feel like it's draging an makes a squish squish noise(this happens when taking off or the speed gauge is above 20 mph) can you please tell me what is the problem
thanks
HMAC300
  • 48,601 POSTS
It may be a transmission problem. Check your fluid and make sure it's full. If your check engine light is on then have it scaned, most auto parts stores do this for free. Have a trans guy check the trans, they will scan it as well as the auto parts stores will not pickup those codes.
CHUCK APODACA
  • 2001 BUICK REGAL
  • 6 CYL
  • 140,000 MILES
It idles fine but when you step on the gas it bogs down. I have changed the plugs, plug wires and coil whats next?
Friday, August 23rd, 2019 AT 1:41 PM (Merged)
DOCFIXIT
  • 18,828 POSTS
This sounds like you have a catalytic converter that is plugged or you have weak fuel pressure here are three guides to help us find the problem.
https://www.2carpros.com/articles/engine-has-low-power-output
and
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
and
Cheers, Ken
CMGILLAM
  • 0 POST
Thanks for the guides I had this problem and when through the guides to find my fuel pump has shot so Installed a new one everything is working great again, thanks!
CHADEEE
  • 2000 BUICK REGAL
  • 6 CYL
  • FWD
Feels like when you give it gas it doesnt take it and boggs down
Could be caused by one of the following below
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it and keep testing.
BOXMAKER75
  • 2002 BUICK REGAL
  • 6 CYL
  • FWD
  • 99,000 MILES
I believe I purchased bad gas. The car is sputtering and has loss of power. Can it be fuel filters?
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
EGR Valve
False air leakage.
Fuel contamination.
Cap and rotor.
