Code P2106 and P2173 driving and engine stalls
  • 109,874 POSTS
Have you checked to see if there is spark and fuel getting to the engine?
Thursday, January 31st, 2019 AT 10:23 AM (Merged)
JUILES
  • 2003 KIA SEDONA
  • 136,000 MILES
After about 30 min (give or take), and sometimes a heavy rocking of the vehicle from side to side, it will start again but feels like it lacks power.."
Battery & alternator have been replaced twice.
Could it be a clogged fuel filter?
KHLOW2008
  • 41,814 POSTS
It could be anything and when it could not be started, you need to check what is missing, fuel or igniton sparks.
Try this link
L POWELL
  • 2004 KIA SEDONA
  • 145,000 MILES
Filled the fuel tank when tanker was unloading at station. The vehicle appears to have run out of fuel. After being towed home car started up and ran for 4 days before same thing happened.
Could my filter be clogged? Where is it located? Web says on the firewall drivers side AND another says in the fuel tank. Or could it be the fuel pump working intermitant?
Thursday, January 31st, 2019 AT 10:24 AM (Merged)
WRENCHTECH
  • 20,761 POSTS
First off, that is something that you never want to do as you have found out. Them filling the tank stirs up all the crap in the bottom of their tank and you sucked it up. You most likely have ruined the pump now.
The fuel filter is part of the pump inside the tank.
YESPLEASE
  • 2004 KIA SEDONA
  • 6.5L
  • 6 CYL
  • 154,000 MILES
Problem is I have a Kia Sedona 2004 it runs great but 1 1/2 months ago I had to replace the fuel pump the car ran great. 3 weeks later at one finger nail above empty the van shut down I pulled to side of road. Some one suggested I might be out of gas So I put gas in and it started I then filled the tank. About 2 weeks later at one finger nail above 1/3 of the tank full the van shut down I pulled to side of road I then put gas in it started right up but the tank did have the gas in it but once more I filled it up one week ago the same thing but at one finger nail above 1/2 I filled it up but I could only get 4 gal in Saturday September 20 the van shut down I pulled to side of road got gas started right up I could only get $20 worth gas in tank now at a full tank the same but stuck at Safeway with full tank and the meter shows a full tank but vehicle acts as if there is no gas any Ideas I will donate if its the problem
KHLOW2008
  • 41,814 POSTS
Is the Malfunction Indication Light showing and have you checked for trouble codes?
When engine could not be started, did you check what was missing causing the non starting?
YESPLEASE
At no time did the check engine light come on the vehicle just shut down A friend did put an OEM /OBD reader ( I think that's what you call them) reader on it did not give any codes.
The only thing I did was to add gas and it started right up.
KHLOW2008
  • 41,814 POSTS
Since problem started after replacement of the fuel pump, I would start with that. Check to see if the fuel pump connections are good, especially inside the fuel tank. A poorly connected hose or strainer can result in fuel supply disruption.
HAMMACK
  • 2002 KIA SEDONA
  • 110,000 MILES
Loaned my car to niece. She said she was driving down road car quit running as all lights including engine lift lit up before it diedl. Towed to dealership and they said main relay switch under hood was missing. They said it was not possible to be driving along and this happening. Is this possible?
KHLOW2008
  • 41,814 POSTS
I believe it is a relay and not a switch. If anything that controls the engine is missing, it is not possible to start let alone drive the vehicle. Did reinstalling the relay solved the problem?
LENNY10TO10
  • 2004 KIA SEDONA
  • 110,000 MILES
2004 Kia Sendona 2.9 manual -EWL comes on under load at 60-70 mph. Then unable to select any gear until the engine is stopped and retarted and left running for 3-5 mins
KHLOW2008
  • 41,814 POSTS
Get a scan done to check for trouble codes. An error has been detected and the fail safe has been triggerred.
