code p0705
AUTOMATIC
GABY2006
  • 9 POSTS
the problem started when ever i went in to pump gas i fill up the thank full when i turn on the car to move on i notice that the check engine light when on and d light started to flash. i was running well but the transmission started to act weird when i hit the break going on 20 miles felt weird going on for 40 or more it felt good like nothing happen. my mechanic bearly put another transmissio like two months ago it was working really good. my mechanic change the trans range sensor still doing same thing, check all the voltages on the sensor everything looks good they even try changing to a different computer but with the other computer didnt turn on at all i dont know what else to do my mechanic cant find anything wrong hes been with my car 1 month ago and nothing what could it be??
May 24, 2015 at 2:48 PM
HMAC300
  • 48,601 POSTS
its' either a short in wiring or the transmission range switch is bad he'll have to scan and check for short's.
May 24, 2015 at 11:11 PM
GABY2006
  • 9 POSTS
actually my mechanic already put a new transmission range sensor and check wiring and still doing same thing he reset the computer and later on still com8ng up the same code p0705 and same issue
May 25, 2015 at 7:28 AM
HMAC300
  • 48,601 POSTS
then more than likely you have a short between sensor and tcm/pcm he'll have to trace it down.
May 25, 2015 at 8:16 AM
GABY2006
  • 9 POSTS
thanks for the answer ill let him know hes been tracking the voltage from all connectors. Do you think this is something to do in general of the transmission? they put one and gave me 6 months of warranty
May 25, 2015 at 9:22 AM
HMAC300
  • 48,601 POSTS
I kind of doubt it as the sensor is on the outside of trans. unless the wiring inside of trans is screwed up
May 25, 2015 at 9:25 AM
GABY2006
  • 9 POSTS
ok thank you very much hopefully he finds the pro lem cause its been a month already and i need my car. ill tell my mechanic to check the transmision again but he says its fine.But i dont want the warranty to expires and have to pay again. thanks
May 25, 2015 at 9:48 AM
