P0740 TCC Solenoid Circuit/Open
2003 HONDA CIVIC
LARRY6354
  • 20 POSTS
P0740, no engagement at all. ? Mechanical or solenoid. Thanks
Aug 26, 2010 at 2:01 AM
KHLOW2008
  • 41,814 POSTS
Hi larry6354,
You need to perform diagnostics to find uot if it is the solenoid or wiring problem.
Mar 1, 2019 at 11:08 AM
DAVEDOG
How difficult is this as a DIY project? Thanks!
Jun 19, 2020 at 6:11 AM (Merged)
KHLOW2008
  • 41,814 POSTS
Yes, not a difficult job if it is only replacing the solenoids but ptorblem could be more than that.
DTC P0740/40: LOCK-UP CONTROL SYSTEM
1. Using scan tool, retrieve A/T freeze data. Clear DTCs and road test vehicle under same conditions freeze data was recorded. If DTC returns, go to next step. If DTC does not return, problem is intermittent. Check transaxle and PCM connections.
2. If any other DTCs are present, repair those DTCs first, then recheck for DTC P0740/40. If no other DTCs are present, go to next step.
3. Test line pressure. If line pressure is within specification, go to next step. If line pressure is not within specification, repair hydraulic system as necessary.
4. Replace A/T clutch pressure control solenoid valve "A"/"B" and torque converter clutch solenoid valve. Turn ignition off and clear DTCs. Ensure engine is at normal operating temperature. Road test vehicle in "D" position at speed greater than 55 MPH for more than one minute. Check for DTCs. If DTC P0740/40 returns, replace transaxle and torque converter. If DTC P0740/40 does not return, system is okay.
NOTE:
DO NOT perform this test procedure until all other DTCs have been repaired.
ACHILLES555
Hello, my car has the check engine light turned on and the code is a P0740 (Torque Converter Clutch Circuit Malfuction). I went to a transmission specialist and several repair shops, all said different things. What are the most probable causes of this code? If the transmission has to be replaced, should I rebuild it or install a different transmission? If I do rebuild it, what is a fair price?
I wiil have the TCC solenoid/circuit checked out-
FAHQUMALL
The torque converter does not seem to be engaging, once up to temp drive 55 no load for approx 2 miles cel comes on and p0740
  • 110,244 POSTS
The code indicates a problem with the transmission lock-up control system. Check the following:
Low or dirty fluid
clutch solenoid valve wiring for opens or shorts
a corroded plug causing a poor connection
If everything checks good, most likely the torque converter is over heating due to little flow to it.
Jun 19, 2020 at 6:12 AM (Merged)
THECORY
I drive a 1999 Honda Civic, automatic transmission, 254,000 miles (yes, you read it right, 254,000). Last April the check engine light came on and I took the car to a mechanic. The code was P0740. I was told I needed a new transmission. I went to the dealer for a second opinion, same recommendation. I was prepared to retire the car, but a friend recommended a mechanic to me, so I gave it one more shot. He, of course, got the same code, but checked the transmission fluid before jumping to conclusions. It was extremely dirty, so he told me it was worth a shot to have that replaced and see what happened (the car was acting completely normal, there was no change in performance during all this). He replaced the fluid (and said there was no metal in it), and the light stayed off for about 1000 miles. I went back to him when it came back on (still no change in performance.) He changed the fluid again, and said you can't get all the fluid out the first time. About 10,000 miles later, the light came on again. I had a friend check the code and it was, once again, P0740. He freaked out and said I needed a new transmission, just like most the other mechanics. He turned off the light, and the next day I took a trip from Pensacola to Ocala and back. No problems, car ran like a dream, no check engine light. The day after I came back the light came on. I just disconnected the battery and reconnected it to turn off the light. It has not come back on (another 300 miles), Car is still running beautifully, I do regular oil changes, check the transmission fluid frequently, and maintain general maintenance. Do you think there is anything to be concerned about, or am I begging for a disaster?
One more thing, I had used the car when I delivered pizzas (about a year and a half...appx 35,000 of the miles were stop and go pizza delivery). Don't know if that info is related at all.
Good luck cracking this case, and thanks so much!
BRUCE HUNT
  • 3,754 POSTS
You know after reading what you have given us, I would opt for a replacement of the sensor itself on the tranmission. I might also look for a possible grounding issue or wiring problem with the wire harness to the tranny. It is obvious after over 11,000 miles that the tranny is probably not the issue.
THOMASWIN11
Hi, i live in ga and im wondering if its safe to drive to florida with a engine check light on that has the code p0740?? this is important because my cousins graduation is coming up and i dont have the time to get it fixed right now.
thank you.
  • 31,937 POSTS
Hi there,
P0740 Torque Converter Clutch Circuit Malfunction
This will be OK to drive, you may experience a small lack of power and fuel economy, but i would not pot off this repair for very long.
mark (mhpautos)
PMP
  • 177 POSTS
Hi, i keep getting this code ive tried everythnig but an coolant temperature sensor. Could this be malfuncionting and making the lock up control systemn not engage? Please let me know. Thank you.
P0740: Torque Converter Lockup Malfunction
Common Problems That Trigger the P0740 Code
Defective Torque Converter Lockup Solenoid
Defective Engine Coolant Temperature Sensor
Defective Torque Converter Clutch
Defective Valve Body
Dirty transmission fluid that restricts the hydraulic passages
MAUIGURU
98 civic, 4dr ex d16y8 automatic 169,000mi. Getting a code p0700/p0740. I believe something about the locking solenoid system (torque converter). I cycled the tranny 4 times with honda fluid. Cleared code and lasted about 45 miles. Replaced lock shift solenoid only. Still getting code. A mechanic cleaned my connectors and it lasted about 30 miles before the code came back on. Should I replace the other two solenoids. Car shifts smoothly. Only bad is I have to drive up a 8 mile hill and the tranny automatically shifts to 3rd the entire road. RPMS are about 4100 @60 mph. Is their anything else I can do before I forego a tranny replacement?
Inspect and test the vehicle speed and throttle position sensors-
RYAN DOLIVER
The po700 code just means that there is a transmission problem and the po740 means the transmission converter clutch circuit. But when I drive it and I am really easy when I press the gas pedal down it does not like thud through first and second, but it still takes longer than it should to shift into the next gear. But when I press on the gas pedal like you normally could with any other automatic vehicle it shifts out of first quick kinda with a big thud and the whole car jumps and then it takes longer than it should to shift into third, and when it shifts into third the thud is a little less and then into fourth its a lot less then fifth it takes a little less longer to shift. I am still not exactly sure where it should be and there is no thud at all. I would like to test the solenoid,s but I do not know exactly where there are located. Can somebody give me pointers I want to fix it myself?
HMAC300
  • 48,601 POSTS
It sounds like the input shaft speed sensor is not working right here is a video to show you how to replace it.
https://youtu.be/f3bETtCIdxM
PMP
  • 177 POSTS
hello, i keep getting p0700 and p0740 there is nothing wrong with the transmission at all. i believe somthing is setting it off. the fluid is fresh. I pulled the freeze data and got
coolant temperature 190 degrees
throttle position 16.8%
engnie rpm 2179
load value 56.8%
map sensor 58kpa
intake air temp 102 degrees
is there anything that looks wrong with this i cant figure this code out.
Thats all at 52mph
KHLOW2008
  • 41,814 POSTS
P0700 indicates that there is a fault with the transmission control system.
P0740 is a fault with the lock-up system and under normal circumstances you would not see any difference in shifting qualities.
The lock-up only affects the few hundred rpm difference when it engages or is not engaged. You would have some fuel consumption increase, other then that you would not note any difference.
