I put the car into first while coming to a stop with the clutch fully pressed in, and encountered resistance in the shifter itself. I have had this issue since I bought the car this year and this time after I forced the shifter into first gear the clutch went to the floor and stuck. I have no resistance in the clutch and had to RPM shift (float gears) to the nearest fuel station. I do not know where to start because my father in law is insisting it is the slave or master cylinder but the reservoir is completely full and show no other sign of leaking. Where should I start for this repair?
Oct 14, 2019 at 1:48 PM
