Whining noise when clutch pedal is pressed down
101,000 MILES • 3.7L • 6 CYL • 4WD • MANUAL
CHILEWINE
A whining occurred every time I stepped on clutch pedal. Drove around block whining got worse. Tested the whining by pressing down clutch and revving gas. Whining got worse and engine stopped. Now will not start and clutch feels tougher to push down.
Feb 22, 2018 at 12:20 PM
Good morning.
It sounds like the throwout bearing in the clutch has failed. it is common for making noise when it fails. the transmission has to be removed and the clutch inspected for the failure. there is a collar the throwout bearing rides on that needs to be checked for wear as well.
Feb 22, 2018 at 3:07 PM
  • 55,852 POSTS
Can you try and put the transmission in neutral will it start?
Cheers, Ken
Feb 23, 2018 at 4:29 AM
