2002 Chrysler Van Failure of Passenger side power window to
2002 CHRYSLER VAN
115,000 MILES • 6 CYL • 2WD • AUTOMATIC
LARNEW
We have had a problem of the passenger side window to operate consistantly.
We've had a dealer try to attempt to fix it with no success. After several attempts (within the warranty period) he claimed it was not actually covered and said he would charge the next time we brought it in.
After that when it failed to open we felt fortunate it failed on the opening cycle and decided not to open it. However there came a time when we did try it and it operated both to open and close so we used it until it again failed to open.
I have heard of other Chysler and Dodge owners who have had this problem, is there something inherent in these brand vehicles regarding this problem?
Aug 2, 2009 at 1:09 AM
JDL
  • 16,098 POSTS
Hello, if there was pattern failure, there should have been a service bulletin, you dealership should have access to all bulletins. I looked through the few bulletins I had, I didn't see anything listed about your problem?
When the window refused to operate, I'd have to check the wiring circuits.
Aug 2, 2009 at 4:16 AM
