2003 Chrysler Town and Country Battery
MISSCONNIE
Chrysler 2003 town and country- will not hold a charge in battery. Battery checked x3 given OK. What next? Will start easly with a jump.
Jan 11, 2007 at 4:28 AM
BOOTDOG
  • 665 POSTS
is the alternator charging properly? if so i've seen it many times where the battery checks good but the battery tester will not detect a dead cell. being that the vehicle is 4 years old now, the battery is probably original and bad. i would go ahead and replace the battery. make sure your charging system is good too. it should charge around 14 to 14.5 volts while the vehicle is running. hope this helps
Jan 13, 2007 at 7:32 AM
Suggested Repair
Verify the charging system produces about 14 to 14.5 volts with the engine running. If charging is normal, replace the battery, since a tester can miss a dead cell and the original battery is likely worn out.
Conversation Summary
The owner reports a 2003 Chrysler Town and Country that will not hold a battery charge. The battery tested OK three times, and the van starts easily with a jump. The expert recommends confirming alternator output at about 14 to 14.5 volts while running and replacing the battery if charging is good, noting that testers can miss a dead cell.
