2005 Chrysler Town and Country radiator fan
2005 CHRYSLER TOWN AND COUNTRY
94,000 MILES • 6 CYL • FWD • AUTOMATIC
TAEVANS
  • 5 POSTS
The radiator fan will not stop running. Where can I locate the relay switch and the sensor.
Mar 16, 2010 at 8:33 PM
BLUELIGHTNIN6
  • 16,542 POSTS
radiator fan relay is at the topof the left front frame rail. the engine coolant temp. (ECT) sensor is on the left side of the engine block.
Mar 16, 2010 at 11:43 PM
MADHATTER503
The relay is located top left (driver) side of the front frame rail, behind the grill. Remove the 5 screws on the top, then CAREFULLY remove the locks on the grill from the bumper cover. Disconnect the neg. battery terminal. The relay may have one or two rivet securing it to the frame rail. Drill out the rivet(s). The replacement part will come with hardware. The temp. sensor is located on the left side of the block. The A/C circuit shares the fan with engine cooling, so the issue could also be there.
Mar 3, 2014 at 4:53 AM
