hard starting
2002 CHRYSLER TOWN AND COUNTRY
DEMEARSJR67
Engine Mechanical problem 6 cyl Front Wheel Drive Automatic 150000 miles
Problem: Hard to start
Replaced: Battery and fuel filter
Tested starter. Tests good.
Just started having this problem.
Go to start it and it takes about 4 or 5 tries.
Has spark.
Been told to replace the O2 sensor.
Starting fluid does make it start easier.
Jun 25, 2010 at 12:44 PM
BLUELIGHTNIN6
  • 16,542 POSTS
test fuel pressure, may have weak fuel pump. is engine light on? if so what codes are showing up?
Here is a guide that can help.
Let me know
Cheers,
Jun 25, 2010 at 12:56 PM
DEMEARSJR67
Typical codes.
PO442, 455 456
Jun 25, 2010 at 1:27 PM
BLUELIGHTNIN6
  • 16,542 POSTS
and fuel pressure?
Jun 25, 2010 at 1:29 PM
DEMEARSJR67
Haven't found the port to check it yet.
Work 10 hour days, 6 days a week.
Should have time to find it tomorrow.
Have turned the key on 3 or 4 times to the on position to see if the pump would kick on.
Did the first time, but didn't after that.
Switched around the relays and still nothing.
Jun 26, 2010 at 1:06 PM
BLUELIGHTNIN6
  • 16,542 POSTS
see if our tips on this issue helps on the following link.. https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Jun 26, 2010 at 5:33 PM
