2001 Chrysler Town and Country Power door
78,000 MILES • 6 CYL • FWD • AUTOMATIC
CDENVER
Hello, Ihave noticed recently that our passenger side power door is not opening. The motor kicks on an unlatches the door, but it won't slide back. Closes fine tho. Is this a temperature thing? I cleaned and reconnected the battery terminal cable and it seemed fine for 4 days.(positive cable) Any suggestions?
Nov 11, 2009 at 12:48 AM
  • 110,246 POSTS
Either the lock solenoid is going bad, the switch is going bad and not allowing enough power to get to the solenoid, or there is a bad connection where it plugs in to the power supply. Remove the door panel and check for general problems. Also, make sure 12+ volts are supplied to it.
Let me know what you find.
Nov 19, 2009 at 12:12 AM
CDENVER
Great! Thanks.......I have also ordered a new latch for the door. Could that remedy the problem? I also noticed that the day I washed the van it was 75 degrees out and it worked like a charm....when it got down to the 40's a few days later it quit working again. Cold here now, so don't know if I want to put unnecessary stress on the plastic door panel? Thnaks again...I will keep you posted.
Mark
402-578-7540
[quote:bccd47d911="Jacobandnickolas"]Either the lock solenoid is going bad, the switch is going bad and not allowing enough power to get to the solenoid, or there is a bad connection where it plugs in to the power supply. Remove the door panel and check for general problems. Also, make sure 12+ volts are supplied to it.
Let me know what you find.[/quote:bccd47d911]
Nov 19, 2009 at 12:31 AM
