I hear a click but the engine does not crank?
150,000 MILES • 6 CYL • FWD • AUTOMATIC
KALCHEK
Hi
When I start the van every morning - I hear a click but the engine does not crank. After 2 or 3 clicks, it starts alright. All other electrical systems seem to be working - I can feel the fan come on, radio and dashboard lights are all ok.
After the early morning starting issue, the next time during the day, it takes one click, but starts on the second one.
Please help me in diagnosing what the problem could be.
Thanks
Kal
Aug 6, 2008 at 8:13 AM
BMRFIXIT
  • 19,053 POSTS
Check the small wire at the starter S terminal and if all ok suspect the starter
good luck
Aug 31, 2020 at 7:06 AM
KALCHEK
Thanks.
Where is the S termina? How do I find it?
BMRFIXIT
  • 19,053 POSTS
locate the starter
starter has two terminals
S terminal is the switch and its smaller then the battery power terminal at the back of the starter solenoid
if u jump them two terminals engine should crank
