1997 Chrysler Town and Country starter won't turn over
RAVENKILLER121
  • 1997 CHRYSLER TOWN AND COUNTRY
Electrical problem
1997 Chrysler Town and Country Front Wheel Drive Automatic
When I try to start my van, it either starts fine (rarely) or it just clicks when I turn the key (mostly) the battery charge is ok, jump starting doesn't help. Occasionally when it will not start I can press the unlock button twice and it will turn over the next time I try, but that happens rarely.
Just wondering if this is a starter problem, a solenoid problem, or a much more complicated electrical problem.
I appreciate your time and I thank you for answering my inquiry.
Thursday, February 18th, 2010 AT 4:42 PM
Your probable causes here could be the starter, starter relay, park and neutral switch/clutch switch and ignition switch assuming the battery and connections are good. If it doesn't apply disregard it
Monday, August 31st, 2020 AT 2:05 PM
