1997 Chrysler Town and Country
ANDRE CURRY
  • 1997 CHRYSLER TOWN AND COUNTRY
  • 6 CYL
  • FWD
  • 183,000 MILES
What could be the reason why my chrysler town and country lxi won't start? When I turn the key it sound like its going to start but it won't turn over.
Sunday, June 13th, 2010 AT 6:31 PM
Lets do below for a start to determine if its fuel or spark related issue and get back with some results
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Monday, August 31st, 2020 AT 2:05 PM
ANDRE CURRY
Just got a tune up 2 weeks ago. Just instlled a bran new ignition coil. Could it be the timming belt or crankshaft sensor?
You need to start testing my suggestions to determine the caused-guessing can be expensive
Related Engine Not Cranking Over Content
