starter not cranking over the engine?
170,000 MILES • 6 CYL • FWD • AUTOMATIC
SPEEDROLIUS
This all started a couple of years ago, and has gotten increasingly worse. First my cruise control quit. (won't even turn on) Then the traction control quit, dash light is lit, but the button does nothing. Check engine light started coming on periodically; now it's always on. Last spring the starting problem began. I would drive somewhere, to work for instance, then when trying to restart the van after a while it starts, but turns off after a second or two. The gauges don't work (tac, temp, gas) but the rest of the dash stuff works, i.e. radio lights, vent/heat, etc. I have to let it sit for a few hours before it'll restart. I've had the alternator check, as suggested by another T&C owner, but it's fine. Someone suggested it may be a short in the column??
Nov 30, 2008 at 10:04 AM
  • 110,244 POSTS
Hi:
Based on your description, I tink you need to have the ignition switch checked. I have gone through a lot of similar problems with these vans and most of the time it's the switch. This guide can help us fix it
Please run down this guide and report back. Let me know what you find. Joe
Dec 1, 2008 at 8:24 AM
SPEEDROLIUS
Ok, cool. I'll check that out today. A friend told me it may be the "ignition module", so I checked for that at the part store, and they said this van doesn't have an ignition module. It's all computers or something. But I didn't ask about the switch.
Thanks!
Dec 2, 2008 at 2:29 AM
