1997 Chrysler Town and Country Engine will not start
JONESKARL
  • 1997 CHRYSLER TOWN AND COUNTRY
  • 4 CYL
  • 185,000 MILES
I have checked the battery, all is okay. I had to add oil, so I did and still no start. The engine is crankin but does not want to grab. What could be the problem?
Wednesday, January 13th, 2010 AT 2:04 PM
No start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Sunday, August 30th, 2020 AT 12:28 PM
Related Engine Not Running Content
How to fix an engine that wont start
VIDEO
